No Grid Bubbles Showing Up
1 REPLY 1
Coaster512
336 Views, 1 Reply
Hi, I have just started learning Revit Architecture by walking through the Youtube tutorials. The only problem I have had is not having any grid bubbles showing up. Is there somethine wrong with my settings or do I maybe have a simple box unchecked? Thank you for your help!
1 REPLY 1
ccollins
in reply to: Coaster512
You should check the Grids and see if you can "Propogate Extents" so they show up in all your views.
Try stretching your viewport/crop region and see if they show up.
Do a search in Help or the Wiki for "Propogate Extents".
As a tip you can also use a Scope Box to control Grids amd Levels in your Views.
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Rail Community
