I've downloaded free Revit 201430 day trial package but it has no dimension stored data sizes for windows, doors walls etc. Why is this as full version has this included in sofware?.
Hello and Welcome to the Discussion!
I am not sure I understand what you mean by no data stored.
Do you mean there is no library components available? The library downloads during the instillation process. If you do not have it then you can go to the control panel and go through the uninstall process - but do't uninstall go in to the Add ore remove features and install the correct content.
The trial version of the software is the full version - it is just set to expire after 30 days.
If this is not what you were refering to - can you explain a bit more.
LD
if your using the online trial
it may not have these components
you may need to download the desktop trial
DarrenP
