Hi Cortney,
There is "Cased Opening" family available in Door folder with Revit Architecture default library. If you will just delete the casing and load into your project then it will solve your problem.
This is located inside the door folder but it is not a kind of Door Family and it is just an opening. You can't place it on the wall using Door tool but you have to use "Component" tool to place on the wall. While you will extract the schedule it will automatically go under Opening category and you don't need to do any adjustment.
Sivate Hussain
Satellier Inc.
Edited by: sivate.hussain on Apr 16, 2009 2:09 PM
I forgot to mention that you can change the Phasing too.
