New to Revit-Printing Sheet Trouble
1 REPLY 1
MMinistrelli
199 Views, 1 Reply
I am pretty new to Revit and I am trying to print a few sheets for the first time.  I was able to print to a PDF with no problem but I have not been able to actually print on my plotter.  When I go to print, it acts like it is going to print my plotter but then nothing happens.  Would you happen to know what I am doing wrong?
Thank you for the help.
1 REPLY 1
vector3
in reply to: MMinistrelli
PDF is just one of your printers. After you get everything setup
and ready to print, hit the print button, and at the top of the print
dialog you can select the printer you want to use for that job.
It might even ask you if you want to set that printer as the
default printer.
