Hi, my name is Kev and I am absolutely new to Revit Architecture 2012. I am working my way through the home tab, and noticed I have NO FAMILIES loaded---no windows, doors, stairs etc---basically I have no 3D objects at all. Can you advise me on how to load these--keep in mind I am completely new so do not understand some jargon. If you could send me info relating to this I would be absolutely appreciated. I am planning on getting onto Lynda.com and I will go through all the DVD's as a means of up-skilling myself to the workings or RA 2012. At the moment I use ArchiCAD 15 and I noticed it maybe similar. Look forward to your reply
Kind regards Kev
Edited by
Discussion_Admin
Kev,
Go to Insert>Load Family then load the families that you want.
Jon
It sounds like you may have started a new project without using a template. Typically you will want to use a template when starting a new project. This way you will have some content loaded when you start working. There are a few default templates that should have been loaded when Revit was installed.
