I completely missed this, so I'm guessing others did too. You would think
it would at least get posted on the Autodesk discussion forums. Excited to
see they fixed the dimension witness lines for cropped objects issue.
http://revit.downloads.autodesk.com/download/9_1/120606_RevitBuilding9.1_20061202_0700.exe
IMPORTANT
Below is the most recent build for the Autodesk® Revit® Building 9.1 and
Autodesk® AutoCAD® Revit® Series-Building 9.1 software products. This update
is made available only to registered users of Revit Building R. 9.1, and is
subject to the terms and condition of the end user license agreement that
appears during installation.
This build, (20061202_0700), addresses several support requests concerning
revit-based release 9.1 project files.
Support requests related to the following areas have been addressed:
a.. Export of projects with linked RVT files to the 3D DWFT file format
b.. Occasional corruptions within default template files
c.. "Cannot load element" messages preventing the ability to Save To
Central
d.. Behavior of dimension witness lines for cropped objects
e.. Visual fidelity of objects when printing files with linked files
f.. Door swings from linked RVT files that would not vector print or
export
g.. Selecting of level annotations
h.. Anomalies invoked by exceeding maximum array size
i.. Loading of families into local files
