We were updating the wall finish schedule in our template. Now using the template, if we create a new room, it's number is 3. Where is the setting that controls what the next available room number is?
TIA!
Don Ireland
Engineering Design Technician
Solved by rosskirby. Go to Solution.
Open the template, create a new room, renumber it as 0, save and exit the template. In new projects, when you create the first room, it will be 1 by default. Revit remembers what the last room number created was, and will number subsequent rooms sequentially. To reset the numbering, you have to create a room 0 as noted above.
Thanks. I guess we were making it too complicated. We were looking for a setting "Next Room Number" or something like that. But your suggestion makes perfect sense.
It'll be addressed on Monday.
Don Ireland
