New construction in existing wall.
4 REPLIES 4
kat
885 Views, 4 Replies
Why can't I see my new wall (in elevation) with new storefronts in an existing wall I edited the profile in to eliminate a portion of that what wall? Also, what are the steps to . . . making a portion of that existing wall, not full height, read demo on my demo plan and seeing it in the demo plan as dashed and seeing the new elements in the new portion in elevation.
Any guidence would be greatly appreciated.
thanks
Kat
4 REPLIES 4
maciejwypych
in reply to: kat
Hi Kat,
I'd like to help but it's quite unclear what your problem is.
An image is worth a 1000 words 🙂 Any chace you can post one? It would be much easier to understand what you mean?
Maciej
Alaaeldin_Alsahli
in reply to: kat
This link may help
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
If not I did a video but unsure what you need so please check the video and let me know if you need any additional information
https://screencast.autodesk.com/main/details/06e030d8-da2c-444c-bdca-0d29193ebbde
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
kat
in reply to: Alaaeldin_Alsahli
No, your suggestion was not of any help. I followed the direction by someone else. I still have to use lines to deliniate the demo portion in the demolition phase. thanks anyway
Kat
adamschaffer
in reply to: kat
I am having the same issue trying to put a new storefront in an existing wall. I get 2 warning messages that the "Wall & instance have different phasing settings. Automatic creation of the infilling wall fails." It does cut the wall. It will show up in elevation if the view phase filter is set to 'Show Previous + New'. You can not select the storefront to cut the geometry or join the geometry once that command is active, I suppose because it's already cut?
I don't get this warning when inserting a door or window.
A solution to get rid of warning would be appreciated.
Adam
