Revit Architecture
Revit Architecture
*Steve Burri
Message 1 of 2 (64 Views)
New build of 7.0 (20041113) is on the web
64 Views, 1 Replies
11-15-2004 01:42 PM
All, A new build of Revit 7.0 has been posted to the Download Center. This build has been posted to address some specific items, including: -------------------------------------------------------------------------------- a.. Some save to central performance improvements b.. Save to central back to same location after upgrade issue has been resolved c.. Some file upgrade improvements were made including: a.. Sheet view corruptions were corrected b.. Grid heads flipping orientation upon project upgrade d.. Applying a view template from one view to another inadvertently copies the view's associated level as well e.. Performance issues related to memory were improved f.. Performance issues related to lengthy project browser were improved g.. Level lines do not show in section unless they are clipped by view boundary h.. Detail elements from family fail to show in project section i.. Export issues, including: a.. improperly positioned section heads b.. improperly positioned liked RVTs c.. Color fills export as white j.. ACIS import improvements k.. Revision method, "by sheet" not remaining persistent between sessions l.. Filled region issues: a.. "white" regions no longer obscure objects b.. Regions cause Revit to exit on print -------------------------------------------------------------------------------- It is strongly recommended that you download this new version if you have downloaded Revit 7.0 in the past.
Active Member
bruntj
Message 2 of 2 (64 Views)
Re: New build of 7.0 (20041113) is on the web
11-17-2004 08:04 PM in reply to: *Steve Burri
Steve,
I have been unable to install PDF writer 4.2 on my computer with both 7.0 and 6.1(ACES version) present. It gets to about 74% installed then quits with errors saying driver cannot be loaded. We have tried it with full permissions, with previous installation uninstall, running Windows Installer Clean Up (our reseller's suggestion), etc. No luck.
Are there any known issues? Any suggestions?
Thank you,
John
