Network file mapping issue & 6.0
2 REPLIES 2
375 Views, 2 Replies
When I try to map library directories I can't see any of my network drives in the browse folder list. All of the other folder lists (i.e. Default template or User files) on the file locations page work fine it is just the libraries. Can anyone help or is this a bug?
2 REPLIES 2
I would say it is a bug. we are experiencing the same behavior. "Frank Murphy" wrote in message news:3ffaca85$1_7@statler... > When I try to map library directories I can't see any of my network drives > in the browse folder list. All of the other folder lists (i.e. Default > template or User files) on the file locations page work fine it is just the > libraries. Can anyone help or is this a bug? > >
I just checked out the zoog forum and this has been discussed over there. It is a bug. However, there is a workaround. Simply type the drive etter - F:\ - for example and then click the browse button. HTH "Eric Stewart" wrote in message news:3ffb2be7$1_4@statler... > I would say it is a bug. we are experiencing the same behavior. > > > "Frank Murphy" wrote in message > news:3ffaca85$1_7@statler... > > When I try to map library directories I can't see any of my network drives > > in the browse folder list. All of the other folder lists (i.e. Default > > template or User files) on the file locations page work fine it is just > the > > libraries. Can anyone help or is this a bug? > > > > > >
Rail Community
