Nesting Familes - implications ?
5 REPLIES 5
MKEllis
271 Views, 5 Replies
I'm putting various doors together, and we have a variety of frame types / door leaf combinations - including occasions where door leafs are inserted in glazed screens (These are timber doors / screens).
It seems to make sense to have the door leaf as a family, then nest those into hosted door frame / screen family. This would allow the 3 or 4 different door leaf types to be switched into the frame / screen combos.
The principal seems to work - but before embarking on the process of putting these together, are there any consequences that should deter me, or that I need to take into consideration ?
Martin
5 REPLIES 5
rosskirby
in reply to: MKEllis
Implications?  Performance-wise, not really.  That's a fairly well-accepted and stable approach to creating door families.
The only real "implications" are for training people on how the door families work (and making sure they do it correctly), and also for using/linking the correct parameters between the host family and the nested family (i.e. door panel height/width/thickness/material and the naming of those parameters.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Chris.Aquino
One thing to watch out for is people editing the nested family from the host family.
For example, Nested family A is nested into host family B and C .Someone edits host family B in the project, then goes into Nested family A, edits it and reloads it into the project.
If the nested family needs to be modified, make sure it's modified on its own, then reloaded into the host families, then the host families reloaded into the project.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
MKEllis
in reply to: rosskirby
Thanks Ross, Since asking the original question I've been experimenting with various setups, and it does seem to work quite well, although I take the point about training and concentrating on a robust arrangement / naming / management regime.
Martin
MKEllis
in reply to: Chris.Aquino
Thanks Chris.
Funnily enough that's the way I've been working on the nested family - mainly because it is easier (opening it directly from the hosting family). I realise now that you've pointed it out; that particular workflow is likely to be prone to breakages in a wider team.
I've worked through the linking of parameters as well - which seems pretty intuitive.
Is there a way of locking a nested family from being edited from the host family - and only allow it to be edited in it's original form ?
Is it possible to set families up to have editing rights assigned to particular users only ? with different users assigned different 'core' families ? I haven't really looked to far into multi-user environments for Revit just yet, beyond establishing and controlling worksets.
Many thanks for the replies.
Martin
Chris.Aquino
There really is not a way within Revit to control who can access what.
If you have Vault, we have seen users store their families on Vault which does have this type of fucntionality.
Chris Aquino
@Aquinotecture
