I have a railing that I created a baluster with I light in it. I did this to represent a "Light Rope" under the Top Rail. But when I share the Baluster family, so I can alter the Light Source, the light does not render.. Is there I'm doing something wrong? When I have the Baluster as an unshared family it will render, but the light is all wrong and I can't tweak it. Any suggestions please?! I have attached the Baluster I'm using
I have the feeling that I miss something from your question.
The family seems to work fine in my case....
I made the following steps:
Your Name
I guess that's my next issue.. Why aren't my Balusters showing the Light Source now that it's a shared family?! As you can see I have the Baluster with the light loaded into railing. They disappear when I share the family. So what about that function is causing this? Thanks for the help guys/gals
At this time, the permanent fix for this issue requires that the code for Revit be modified, and as such, we do not really have a fix, and at this time the workaround would be to not share the light sources.
We understand that this may not be the preferred workflow, but as I mentioned, any change in behavior will require the code for Revit to be modified.
