Revit Architecture
znewkerk
Message 1 of 6 (261 Views)
Accepted Solution
Nested family problem
261 Views, 5 Replies
08-22-2013 08:04 AM
Hello, so I have currnetly made a nested family for a basketball system and have a problem when i flex my elevation. As you can see my bracing that the Red arrow is pointing to is not flexing properly.. However when I edit the family its in, I have it constrained and it flexes no problem. So what could be the solution to this problem?
I've received you file via email. In order to make that portion of the Family obey the "flex", I simply removed the constraint depicted in the image below.
I would recommend heeding or at least considering Alfredo's advice that he gave in from your other thread; the diagonal Reference Planes appear to be creating some instability.
Alfredo_Medina wrote:
"When you deal with diagonals that need to be constrained, there are two good choices: reference lines constrained at the start ponts, or diagonals with their endpoints constrained to horizontal and vertical planes..
Using diagonal reference planes is a bad choice. They require too many constraints to stay in place, and will, most likely, break anyway, producing those errors that you are seeing. I think that is causing you problems in that family."
*Expert Elite*
CADastrophe
Message 2 of 6 (242 Views)
Re: Nested family problem
08-22-2013 09:25 AM in reply to: znewkerk
Can you attached your current Family file? (Even if it's the same file as the file in your other thread)
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
znewkerk
Message 3 of 6 (235 Views)
08-22-2013 10:07 AM in reply to: CADastrophe
I tried sending the file but it exceeds the maximum file size to post on the forum.. Is there another place I could post it or send it for you to look over?
Valued Contributor
revitus
Message 4 of 6 (223 Views)
08-22-2013 11:11 AM in reply to: znewkerk
Without the file to troubleshoot, it is going to be difficult to offer suggestions.
You can check out Performance Sports Systems 3207 (Ceiling-Hung, Front-Fold, Front-Braced Basketball Backstop).
http://www.perfsports.com/document-view/3207-revit-model-1
*Expert Elite*
CADastrophe
Message 5 of 6 (212 Views)
08-22-2013 11:42 AM in reply to: znewkerk
znewkerk
Message 6 of 6 (201 Views)
08-22-2013 12:16 PM in reply to: CADastrophe
That's crazy, I can't believe you found the problem! That was such a tease that it was working no problem in the single family but not in the nested. Thanks Corey, you've helped me out a lot!!
-Zach
Need installation help?
