All revit project and Families files are create 0001.rvt or .0001.rfa tempoary files how can stop this tempoary files.
Solved by LisaDrago. Go to Solution.
These are your back-up files. I would advise keeping one or two - just in case anything happens. But to alter the number of back-ups you can do a save as... In the dialog box there are options - in there you can change the number of back-ups saved. See attached image.
LD
For .rvt files ( Revit Projects ) if you enable Worksets this will stop creation of the .000 backup files.
You must place the .rvt on a Server, make it a Central File.
cheers
