need help, Revit won't work
5 REPLIES 5
797 Views, 5 Replies
I have trouble with with my student version of Revit 2014. I am using a Mac Book Pro, Retina Display, and therefore bootcamp and Windows 7. I managed to install Revit, but as soon as I open a project, I notice some flickering white spots in my bottom task bar. Now I can very slowly try to draw a wall for example, but eventually or when I try so save the project, Revit will stop working. All symbols fade to be grey and the window to save the project won't open. Now when I try to do anything else it won't work. Not even closing Revit. So I have to force it to shut down by using the task manager.
- reinstall the program several times (Revit 2014 and 2013)
- reinstall Windows itself (Windows 7 and Windows 8.1)
- redo the bootcamp partition on my mac
- installed VM - Ware Fusion
- download and install all Windows Updates
- download and install all Revit Updates
- enable and disable the hardware acceleration (Revit, Option)
Do you have any experience with this problem or is there anything I can do?
Thanks, Helena
Tags (2)
5 REPLIES 5
lmalladi
I am facing the same problem! I don't have a bootcamp but I run revit on windows7 and parallels8. I notice the same flickering white spots in the bottom task bar. When I try to import or save the project, Revit stops working.
Please let me know if you have found any solution.
Thanks, Laasya
in reply to: lmalladi
Is there any update on this issue?
I am having the same exact problem running Revit on my mac dual booted with Windows 8. The bottom task bar flickers and the program eventually stops working and I have to force quit.
dandantodd
I am having exactly the same problem. Have you found a solution yet?
ennujozlagam
in reply to: dandantodd
hi all,
I found this discussion on this forum maybe can help.
Please read:
http://forums.autodesk.com/t5/Revit-Architecture/REVIT-2014-ON-WINDOWS-8-1/td-p/4958654
shalom....
