I've tried to remove this file and it does not apperar in the folder
c:\Documents and Settings\%USERNAME%\Local Settings\Application Data\Autodesk\Revit\Autodesk Revit Architecture 2010\ENU\Components\WebServices\WSCommCntrData.xm
I also deleted the webclient folder from the registry and nothing.
My processor supports SSE2 instructions too!!!!!
Any other ideas????
Sorry sir,
I was going to try and offer a useful suggestion like make sure your license hasn't expired, but after reading your post, I have not idea what the he** you're talking about. But I'm not really an IT guy. Unless this is a dialog that's already in process with others more knowledgeable about such things, perhaps you could provide a bit of back ground and context.
Good luck.
My hunch is that there is either something currupted in the installation of the software, or you have a hardware issue (as in dammaged or incompatible components). Obviously Revit isn't supposed to do this. You might also look into security software issues or viruses.
Sorry I can't be of more help. Good luck.
Shawn Graham
Designer.
DarrenP
