Need help_In Revit 2013 the pivot move around when rotating in 3D view
1 REPLY 1
676 Views, 1 Reply
I don't know why the point cloud data in Revit 2013 will cause the issue as the picture shows. I have tested othe people's .pcg & .rvt file, everything is ok. If I only create model, there was no problem as well.
Is there any settings for the inserted pointclouds ? Why other people's pointcloud file .pcg will be ok, but mine.
my regards
Koalar Q
1 REPLY 1
For this issue, I have found the reason. The coordinate influence.
