I am creating a Curtain Wall Panel with Spiders. When I import the family into project and create a curtain wall with the panels applied in type properties, the spiders are not constrained with the curtain grids. Any help or work around is appreciated.
Thanks!
I'm not sure where your panel came from or who created it. I always find it easies to start with something that works then save-as a copy, edit it, load it and test to see if it works. Please see the attached file as I think it will be a good starting point.
Thanks for posting.
