Need help in creating a Curtain Wall Panel with Spiders
2 REPLIES 2
BalajiHTI
378 Views, 2 Replies
I am creating a Curtain Wall Panel with Spiders. When I import the family into project and create a curtain wall with the panels applied in type properties, the spiders are not constrained with the curtain grids. Any help or work around is appreciated.
Thanks!
2 REPLIES 2
alan.quinn
in reply to: BalajiHTI
I'm not sure where your panel came from or who created it. I always find it easies to start with something that works then save-as a copy, edit it, load it and test to see if it works. Please see the attached file as I think it will be a good starting point.
Thanks for posting.
BalajiHTI
in reply to: alan.quinn
Thanks Alan,
Will try your file and post the findings 🙂
