I am currently working on a home where i need to have a single slanted roof go accross the perimeter of the home to form a roof. But, i have run into the issue of not being able to connect the circled area(see attached) Does anyone know if it is possible to connect those seperate roofs and if so how?
Solved by Alfredo_Medina. Go to Solution.
Why does it have to be 2 roofs anyway? Make a single sketch in "L" and problem solved.
