Dear All,
I need colour to a family in floor plan view.I can set the colour to that family in 3D view( by MANAGE - MATERIALS - APPEARANCE).But that colour was not appearing in floorplan view of the family. Is there any option to arrange colour to the family both in floor plan and 3D view.
Thanks in advance for your quick help...
Mahesh
Solved by constantin.stroescu. Go to Solution.
You can do it using Visibilty/GraphicOverride - Filters:
Suppose you want all the furniture to be colored somehow:
Your Name
Thanks for the information.
And there is another issue i am facing.
i had drawn a slab with reference elevation 0'0".Now i need to place a component below the slab(of thickness 10").Means the elevation of placing the component is -10".When i am placing that component below the slab the colouring of the equipment was not appearing.If we place the component above the slab the component coloring is appearing.Now i need colour to the component even if i place the component below the slab.
Please suggest me.
I'm afraid I don't understand you very well....
Let's resume:
You have an object placed under the Level and you want to see it through an opaque floor slab ?
If so, there are, in my opinion several methods:
Your Name
