Não consigo instalar o revit e o 3dmax . O que faço ????
1 REPLY 1
280 Views, 1 Reply
2014/10/12:23:07:53 Luciana LUCIANA === Setup started on LUCIANA by Luciana ===
2014/10/12:23:07:53 Luciana LUCIANA Path_Length: 155
2014/10/12:23:07:53 Luciana LUCIANA Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2014/10/12:23:07:53 Luciana LUCIANA Launch
2014/10/12:23:07:53 Luciana LUCIANA CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US... /skipPI /SN 900-28646086 /PK 829G1 /akamai
2014/10/12:23:07:53 Luciana LUCIANA Current Directory C:\Users\Luciana\AppData\Local\Temp\_AI2BC.tmp
2014/10/12:23:07:54 Luciana LUCIANA === Setup ended ===
2014/10/12:23:07:54 Luciana LUCIANA === Setup started on LUCIANA by Luciana ===
2014/10/12:23:07:54 Luciana LUCIANA Path_Length: 155
2014/10/12:23:07:54 Luciana LUCIANA Current Directory C:\Users\Luciana\AppData\Local\Temp\_AI2BC.tmp
2014/10/12:23:07:54 Luciana LUCIANA Launch
2014/10/12:23:07:54 Luciana LUCIANA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64....
2014/10/12:23:07:54 Luciana LUCIANA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Luciana\AppData\Local\Temp\_AI2BC.tmp\Setup\RevitSetup.dll
2014/10/12:23:07:54 Luciana LUCIANA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/12:23:07:54 Luciana LUCIANA PageOpen LaunchDialog
2014/10/12:23:07:59 Luciana LUCIANA Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Luciana\AppData\Local\Temp\_AI2BC.tmp\Setup\RevitSetup.dll
2014/10/12:23:07:59 Luciana LUCIANA Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/10/12:23:08:22 Luciana LUCIANA PageOpen LicenseDialog
2014/10/13:00:24:49 Luciana LUCIANA PageOpen ProductInfoDialog
2014/10/13:00:24:49 Luciana LUCIANA PageOpen ProductSelectionDialog2
2014/10/13:00:28:27 Luciana LUCIANA PageOpen FullProgressDialog
2014/10/13:00:28:28 Luciana LUCIANA Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2014/10/13:00:28:28 Luciana LUCIANA Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/10/13:00:28:29 Luciana LUCIANA Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/10/13:00:28:29 Luciana LUCIANA Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2014/10/13:00:28:29 Luciana LUCIANA Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/10/13:00:28:30 Luciana LUCIANA Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/10/13:00:28:30 Luciana LUCIANA Download Skipped RCL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RCL2015_x6...
2014/10/13:00:28:30 Luciana LUCIANA Installing Autodesk® Revit® Content Libraries 2015:  TRANSFORMS="C:\Users\Luciana\AppData\Local\Temp\_AI2BC.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/13:02:24:38 Luciana LUCIANA Install Autodesk® Revit® Content Libraries 2015 Succeeded
2014/10/13:02:24:38 Luciana LUCIANA Download Skipped RVT2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x6...
2014/10/13:02:24:39 Luciana LUCIANA Installing Autodesk® Revit® 2015:  TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2015\x64\en-us\RVT2015\RVT2015.mst;C:\Users\Luciana\AppData\Local\Temp\_AI2BC.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/13:02:27:44 Luciana LUCIANA Install Autodesk® Revit® 2015 Succeeded
2014/10/13:02:27:44 Luciana LUCIANA Download Skipped RVT2015_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x6...
2014/10/13:02:27:44 Luciana LUCIANA Installing Autodesk® Revit® 2015 Language Pack:  TRANSFORMS="C:\Users\Luciana\AppData\Local\Temp\_AI2BC.tmp\_laF88A.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/13:02:27:59 Luciana LUCIANA Install Autodesk® Revit® 2015 Language Pack Succeeded
2014/10/13:02:27:59 Luciana LUCIANA Installing Autodesk Workflows 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/13:02:28:03 Luciana LUCIANA Install Autodesk Workflows 2015 Succeeded
2014/10/13:02:28:03 Luciana LUCIANA Download Skipped CMILL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILL2015....
2014/10/13:02:28:03 Luciana LUCIANA Installing Autodesk Material Library 2015 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/13:02:28:25 Luciana LUCIANA Install Autodesk Material Library 2015 - Low Image Library Succeeded
2014/10/13:02:28:25 Luciana LUCIANA Installing Autodesk® BIM 360™ Add-in for Revit® 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/13:02:28:28 Luciana LUCIANA Install Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded
2014/10/13:02:28:28 Luciana LUCIANA Download Play CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILM2015....
2014/10/13:02:37:56 Luciana LUCIANA Download Aborted CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILM2015....
2014/10/13:02:37:56 Luciana LUCIANA Install Autodesk Material Library 2015 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2014/10/13:02:37:57 Luciana LUCIANA Rollback Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded
2014/10/13:02:38:04 Luciana LUCIANA Rollback Autodesk Material Library 2015 - Low Image Library Succeeded
2014/10/13:02:38:05 Luciana LUCIANA Rollback Autodesk Workflows 2015 Succeeded
2014/10/13:02:38:10 Luciana LUCIANA Rollback Autodesk® Revit® 2015 Language Pack Succeeded
2014/10/13:02:39:53 Luciana LUCIANA Rollback Autodesk® Revit® 2015 Succeeded
2014/10/13:02:45:22 Luciana LUCIANA Rollback Autodesk® Revit® Content Libraries 2015 Succeeded
2014/10/13:02:45:22 Luciana LUCIANA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/10/13:02:45:22 Luciana LUCIANA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
1 REPLY 1
ennujozlagam
OLÁ você pode conferir aqui. ESPERO QUE AJUDA A TI
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
