Name cannot contain any of the following characters: \ : { } [ ] | ; < > ? ` ~
5 REPLIES 5
kingsley.mcrae
10468 Views, 5 Replies
As a project requirement, I must have the symbol | separating the text in my drawing title/sheet name field on my titleblock family. When entering that symbol I get the error message
or any of the non-printable characters.
Why? When on normal text fields they can be used? Is there a way around this?
thanks in advance,
Andy
5 REPLIES 5
L.Maas
in reply to: kingsley.mcrae
Depending on how your workflow is. For example you could consider to make the | part of your title block.
Basically fill in the drawing title and sheet name (without the | ). One parameter you right align, the other you left align next to the | on the sheet.
Or instead of using the default parameters create a new (shared) parameter where you can use the |.
Louis
Please mention Revit version, especially when uploading Revit files.
Sheet names are used, or can be, to create exported files like DWG/DWF/PDF. If a symbol can't be used to create a file name then it can't be used in a sheet name.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
CoreyDaun
Depending on the font used, there may be an alternate character that you can use, instead. For instance, in the Arial font, there is another "vertical line" character that might work for you. See image below.
dfurball420
in reply to: CoreyDaun
You can use a forward slash "/" but not a back slash "\"
adper27
This is not resolved. The problem here for the structural side is it varied some elements in terms of depth and width. You can't rename those characters in type properties to achieve your beam, column, & wall marking, etc. But the only I can do here to achieve my marking is to mask it with text.
