I have a mystery window pop up everytime i start Revit. (see attached pic). It's the little window in the middle. If I right click it I can move it and close it but if I minimize Revit it will come back. It will also come back when i open a new family or project. Has anyone else come across this?
Solved by Dion_Roland. Go to Solution.
This is a video card problem. Not sure what your video card is, but I have the same problem. I have a AMD FirePro V4900
I get rid of the window by disabling Hydragrid in the Hydravision tab of Catalyst Control Center.
Thanks. I have a NVIDIA Quadro 2000D. I will play with my setting and see if i can get it go away. If i can i will report back.
Thanks again.
I played with the setting and I still had the problem. So I installed an older driver from Nvidia and it fixed the issue. I installed the 307.45 driver.
I have the same thing little thing always appearing that I need to take out after I start the program. It was also in Revit 2013. Is this not something that Autodesk should have dealt with for some time by now?
