My Revit has not got any symbols and things
6 REPLIES 6
letreetleneant
435 Views, 6 Replies
I setup the Revit Architecture student version newly.
Here I upload some screenshoots as attachment.
Revit has not got the symbols and other things like these in my computer.
Thanks for help...
Tags (1)
6 REPLIES 6
CoreyDaun
in reply to: letreetleneant
It appears as though your Project was created without a Project Template. When you start a new Project, you should be prompted to select one.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
letreetleneant
in reply to: CoreyDaun
There is no template.
You skipped installing the content when you installed Revit.  Here's how to install the content:
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00005-More_Inf0/0138-Installa138/0140-Revit_In140/0...
Scott D Davis
Sr AEC Technical Specialist
No i did not skip them. I installed 3 times for checking
Try this:
Control Panel>Add/Remove Programs>Revit>Repair
This may enable you to install the Content that is missing.
letreetleneant
I did it but it still the same
