my building is gray - Why
3 REPLIES 3
1064 Views, 3 Replies
Hello ...
I have this project that creates some problems. We are a team so we work with local files and central files. there are 5 local files, and a central file on a network drive, all PCs running LAN connection (not WiFi)
All run Revit 2013
problems:
First As you can see in the picture is a large part of the building gray and some are not, why?
Second wall down the run is on a one 3D view but not on others.
3rd The wall of Question 2 is not in the plans
3 REPLIES 3
subsales
in reply to: 1007919
most comen thing here are the phase settings.
check the view settings for the relevant view, which phase the view is on and the phase filter.
Regards, Kirstin
LisaDrago
The First thing I would look at is the wall you are using and that a material has been established and not just the default.
Second I would check to make sure the exterior side of the wall was really on the 'outside' - the quickest way to check this is to pick a wall and the side with the double arrow (flip arrows) is the exterior side.
I would start there and if those are all good - I would go to the phasing and visibility graphics.
Let us know what you find.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
MhamedZouheir
Check VG Wall category Projection/surface pattern
Rail Community
