Revit Architecture
New Member
1007919
Message 1 of 4 (332 Views)
my building is gray - Why
332 Views, 3 Replies
09-25-2012 02:04 AM
Hello ...
I have this project that creates some problems. We are a team so we work with local files and central files. there are 5 local files, and a central file on a network drive, all PCs running LAN connection (not WiFi)
All run Revit 2013
problems:
First As you can see in the picture is a large part of the building gray and some are not, why?
Second wall down the run is on a one 3D view but not on others.
3rd The wall of Question 2 is not in the plans
subsales
Message 2 of 4 (312 Views)
Re: my building is gray - Why
09-25-2012 03:30 AM in reply to: 1007919
most comen thing here are the phase settings.
check the view settings for the relevant view, which phase the view is on and the phase filter.
Regards, Kirstin
LisaDrago
Message 3 of 4 (291 Views)
09-25-2012 07:37 AM in reply to: 1007919
The First thing I would look at is the wall you are using and that a material has been established and not just the default.
Second I would check to make sure the exterior side of the wall was really on the 'outside' - the quickest way to check this is to pick a wall and the side with the double arrow (flip arrows) is the exterior side.
I would start there and if those are all good - I would go to the phasing and visibility graphics.
Let us know what you find.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
New Member
AUTO001519
Message 4 of 4 (287 Views)
09-25-2012 07:43 AM in reply to: 1007919
Check VG Wall category Projection/surface pattern
