Multiposition mechanical equipment family creation
2 REPLIES 2
314 Views, 2 Replies
I am having trouble figureing out how to make a rotateable mechanical equipment family for a horizontal or vertical furnace.  The MFG dosen't have one made for this is as it is a "residential" product.  They do have one for there fan coil, that I can choose if its horizontal or vertical, but I can't for the life of me figure out how they did this.  I am using 2014 Revit.  Thanks in advanced.
2 REPLIES 2
L.Maas
To make something rotate in Revit the standard procedure is as follows.
-Open a family template and model your component
-Make sure that the family has Work Plane-Based activated and Always vertical deactivated.
-Start a new family.
-Add a reference line and constrain it. Add an angle parameter.
-Load the other family you created in step one in this host.
-Attach the family to the reference plane
Now you can rotatt your component. You can further constrain it with formulas to limit it to two positions if needed.
A good and more detailed tutorial can be found HERE.
Louis
Please mention Revit version, especially when uploading Revit files.
in reply to: L.Maas
Thanks!  It's been a fun battle having taught my self autocad and now being foreced to learn revit without an instructor/classroom setting.  I'm doing alright though,  appricate the help.
