Is there a way to flip face multiple times? I have lots of composite window in the external wall of my model which someone has placed the wrong way round, at the moment I’m just flipping one window at a time.
S.
Solved by Joe.Charpentier. Go to Solution.
I don't think there is any way to flip multiple elements at once, even if all of the selected elements are identical.
Select all the windows you want to flip, then hit the spacebar.
Joe
@Anonymous wrote:I don't think there is any way to flip multiple elements at once, even if all of the selected elements are identical.
Do you know if flipping the workplane on multiple items is available on multiple items in 2014? And I am referring to workplane, not 90 degree orientation as the OP was inquiring about.
NICE
Found this add-on for flipping workplane on multiple elements. Our I.T. guy will not let us download it yet so I am not sure how well it works.
https://apps.autodesk.com/RVT/en/Detail/Index?id=4825202806152148653&appLang=en&os=Win64
