Actually, I discovered if I hit settings on the Room and Area tab, I can designate a new type of area plan. (which is what I wanted to do). Duplicating the view with detailing is what I did originally, but if you test this out, you'll see it doesn't actually create an unrelated drawing to start fresh with. If you edit an area plan in one 1st floor plan, it will edit it in all of them (in that family). I haven't tried the design options yet, but I will test it out. Thanks for all your help and suggestions.
