Hello
Is it possible toe make a dimension line with multiple (2) alineas where I can put my text?
ex. at a window in plan view we put first the length (automatically done by revit) then the hight (manual) and then how high from the ground the window starts.
In autoCAD we can put the last input under the first two with the command "\P"
I will add 2 images, it is the look of the AutoCAD dimension that I would like to become in Revit.
Can somebody help me?
Ok I found a solution but I still have a question.
It is possible with linear dimention to put text above and under the value.
But is it possible to do this with an aligned dimention?
