Marc Isabelle wrote:
> I wanted to specify levels in m and all other
> measurements in mm.
Set your project units to mm.
In the Project Browser, Families, Annotation Symbols, find the symbol
being used for your levels (mine is "Level Head - Circle").
Right click on it, select "Edit". "Yes" to open this symbol for editing.
Select the Elevation label, click the "Edit label..." button.
Select the Elevation parameter on the right side, click the button at
the bottom with a hand pointing to the # symbol to "Edit Parameter's
Units Format".
Uncheck "Use project settings". Use the drop-downs to specify meters,
whatever rounding you would like, etc.
Load into your project.
Brian Winterscheidt
LWPB Architecture
Oklahoma City, Oklahoma
