<archmohammeds> wrote in messageHi
href="news:6054149@discussion.autodesk.com">news:6054149@discussion.autodesk.com...
everyone i have a problem of creating multi-landings(flights) stair (i.e. 3
flights) . revit is showing an error message for the creation:("Highlighted
lines overlap. Lines may not form closed loops.").If i ignore the message
Revit will creat it but the handrail will look strange and cannot be fixed!
Any help? thank you in advance Edited by: archmohammeds on Oct 19, 2008 5:05
AM
You tried to create a stair with three runs, but cannot because the flights
overlap.
Stairs cannot overlap each other. However, by manipulating parameters and
creating two stairs on top of each other, you can create a three-run stair. Here
is the basic methodology:
To create the first and second run
To create the third run
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
<melarch> wrote in messageJeff,
href="news:6054372@discussion.autodesk.com">news:6054372@discussion.autodesk.com...
Could not find the link.
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and Realize Solutions
Modeling for the
Future/Drafting in the Present/Building on the Past
The other way workaround is to setup the third run boundary lines offset a very little distance from the bottom ones, so they are literally not overlapping. vola.
