Well, with AutoCAD we typically publish files for the same project- which are housed in a common project folder. With Revit, all the sheets are housed in the same Revit file and, within a project it's really identical (only better in some ways) to the publish command. I guess we haven't had the need to publish sheets from different projects in the same publish operation.
