Has anyone built a MS Access database that can export Family Tables? Or knows of a 3rd party application that all the type information can be houses in a database, and the family table's TXT is just an export. The family tables we create are nemorus, and lengthly family tabels, and Excel just is not cutting the mustard.
Or would Autodesk ever include this in Revit?
There is an add-in/Extension from Autodesk called DB Link that can do this. I believe it is available on the Subscription Center.
cheers
This is what I found, don't feel like this is hwat I am looking for:
did not see "export family tables"
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=13917027
Autodesk Revit DB Link
Import and export data between a Revit MEP 2010 project and an external database, and then more easily maintain relationships of linked data with Autodesk® Revit® DB Link.
Can you explain a bit better what you are trying to do?
Are you trying to Export Familiy info from Revit and use it in MS Access?
Are you trying to type infi into MS Access and then Import it into Revit?
Have you tried exporting ODBC from Revit?
cheers
we are in the process of building family tables TXT files that accompany our RFA files. -
and it is a process that will never end
To keep things generic lets pretend my revit family is one style of a bicycle. this particular bike comes in:
... disclaimer …the revit families in this post are largely fabricated, the issues of truth within the memoir genre, by using a non-fiction name and changing the name of types in the post, this will exclude you for a libel case: Falsely accusing someone of a bicycle manufacturing, or having been charged family fraud a disclaimer that informs will fairly represent my question ...
6 colors,
4 styles of handle bars
5 grip styles for each handle bar
oh and you can get 4 different rims
2 frame styles (mens/women's)
2 sizes 20 & 26
if you do the math, 480 types in this one family table.
so if you attempt to build a 480 lined family table in say Excel, and each time any one of these 6 parameters changes, it changes the type name, type description, and model number, all the data links found in the TXT file.
You start asking yourself, maybe I cold add all these tables into MS Access and build a relational database that exports Revit Family Type Catalog TXT files based on whatevr fields are in my database.
Then later when marketing adds options for pedals, cranks, seat, forks, and the little bells it can all be generated from the database.
So you say you'd never have 480 types in a family, then imaging we make 25 different each of bikes, tricycles, scooters, recumbents, and unicycles, and I hear we are getting to those walker the old folks us
That helps explain it a bit.
However, I would NOT recommend a "super-family" that contains 450 Types. Great for family creation;
HORRIBLE for performance once loaded into my Revit project!
That said, I think there IS a way to do what you are trying to do, via ODBC, some kind of 3rd party DB app/plug-in for Revit;
or perhaps the API? Try posting your question here:
There are some serious Revit gurus over there who may be able to help you better than I can.
cheers
