Revit Architecture
Active Contributor
M-Town_Drafter
Message 1 of 5 (186 Views)
Moving wall deletes tags
186 Views, 4 Replies
04-15-2013 08:03 AM
I'm trying to move a wall.  When I do, I get this warning 'Elements will be deleted', which apparently means that all tags for the wall and anything hosted by it in the interior elevation views.  Huh?  Oddly, if I drag it, this doesn't happen.  This resulted in a frustrated yelling session with inanimate objects late last night.
So, what am I doing wrong?  Or, if this is just Revit being Revit, how can I prevent it, besides dragging elements for slight modifications to 24 restrooms with a deadline fast approaching?
Mondays.  I never could get the hang of Mondays....
Any advice on this would be greatly appreciated.
Additional: I'm using Revit LT.  I've also noticed that aligning, or using a dimension to move the object does not result in tag deletion.  Just the move command.  I'll be checking this on a full version soon.  If it doesn't do it there, I'll be saved for this project.
My guess is that you had "Disjoin" checked on in the "Move" command. The setting I think is persistent per Revit session, but resets itself after a restart. See screenshot.
Active Contributor
M-Town_Drafter
Message 2 of 5 (171 Views)
Re: Moving wall deletes tags
04-15-2013 08:41 AM in reply to: M-Town_Drafter
Huh... i restarted Revit, and now it allows the move without deleting the tags.  I suppose a fix is to restart Revit whenever it exhibits this behavior, but I was only 2 hours in this morning.
...or maybe I'm going insane... I suppose that's another possibility...but at least I'm one of the happy kinds...
Active Contributor
chris.needham
Message 3 of 5 (143 Views)
04-15-2013 02:21 PM in reply to: M-Town_Drafter
Chris Needham
Whangarei
New Zealand
Active Contributor
M-Town_Drafter
Message 4 of 5 (138 Views)
04-15-2013 02:27 PM in reply to: chris.needham
Ah ha.  That was it.  I was trying to keep several nearby walls from joining in on the fun, so to speak.  So, operator error concerning documented behavior.  Much better than wondering what was happening and why.
Should I apologize to revit for all the nasty things I said to it last night?
Thanks!
Active Contributor
chris.needham
Message 5 of 5 (128 Views)
04-15-2013 02:38 PM in reply to: M-Town_Drafter
Have been caught with the "Disjoin" trap before. Personally, I wish the was some sort of setting where users could tell Revit to have it stick for just the one command, or until explicitly unchecked.
M-Town_Drafter wrote:
.................................Should I apologize to revit for all the nasty things I said to it last night?
Thanks!
No, I wouldn't apologise.......we all do it a fair bit I'd say :smileywink:
Chris Needham
Whangarei
New Zealand
