I am working with massing and am trying to move a basic shape I’ve created, however it will only move orthogonally. Is there a setting that allows me to move it on an angle?
Phil
I understand you cannot move your Mass in Revit. After you highlight your Mass in Plan and click Move make sure the Constrain button is un-checked, then you should be able to move you Mass at an angle. See attached image for details.
If this dose not work please attach your Mass and instruction on what you are trying to do and in what view you are working.
Thanks! This helped even in 2023, but I had to check the "Disjoin" after un-hooking the "Constrain".
