I like my Level Heads on the right side of the drawing and have set up my elevations accordingly. However, when I went to one of my elevation views, I noticed they had moved to the left side of the drawing. I “stretched” them back, and now the others are all off. Is there a tutorial that addresses this so I can see what I can and cannot do to get them to all align alike?
Thanks, Phil
If you want to swap the head position, you can select the level line and tick/un-tick the box at each end, this will toggle the head On/Off. The same thing can be done inside the type properties of the level line (Symbol at end 1 etc.) ticked or un-ticked.
When you select the level line, you will notice at each end it will say (in very small text) either "2D" or "3D". If it is set to 3D, you are moving the 3D extents, meaning if you stretch it in the east elevation, you will be moving the west elevation and any framing elevations or sections with the same orientation, and the same goes for North/south. If you click the wee "3D" text on the level line, the grip changes to a small dot, if you move the 2D extent, it only affects the current view, and does not modify any other view.
You can swap between the two by clicking the "2D" or "3D" pieces of text on the level lines.
(you cannot use 3D extents if the view is cropped and the levels are outside the crop region)
Hope this helps
is there any effect for being the MEP levels on the right side for example and the Arch link levels on the other side ?
and what is the difference between levels heads on the right and left side ?
thank you
