Revit Architecture
Revit Architecture
JamaL9722060
Message 1 of 4 (529 Views)
Moving introduce “Can't keep elements joined”,
529 Views, 3 Replies
10-06-2012 02:47 PM
I tried to move my drawing to make it at the center of the elevation tags but I have a message saying “can't keep elements joined”
What is the effect of accepting or rejecting this message?
Also, I’m wondering if there is a command that place the drawing at the center of the elevation tags.
Thank you for the help,
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Moving the entire building (while possible) is not recommended, especially for such as trivial purpose. The error you are getting there means that some of your elements are going to lose their association with each other. Not good. Also, there are many issues that will crop up, especially with others who are coordinating with your Model. Additionally, it is probable that may not select every element, which will cause more problems of course. And lastly, moving the entire model will cause significant problems with your Annotations in your Views. You'd have to go to each one to relocate any text, generic annotations, etc.
Simple answer: DO NOT move the model. Instead, mode the Elevation Tags to accommodate your model's position.
Valued Mentor
gh_ar
Message 2 of 4 (504 Views)
Re: Moving introduce “Can't keep elements joined”,
10-08-2012 02:48 AM in reply to: JamaL9722060
Two approaches to this problem however it seems to me you think
1 - First, get into a 3D view, and click and drag to select all the elements.
- The 2D view, for example, plane (level) down the Ctrl key elements of the plan and go with the next two, for example,
choose a  Dimenssion line.
You can now use the Move Tool to move the elements.
2 - The second method:
You can open a new file and the files in it to Link.
CADastrophe
Message 3 of 4 (498 Views)
10-08-2012 05:31 AM in reply to: JamaL9722060
JamaL9722060
Message 4 of 4 (477 Views)
10-08-2012 01:22 PM in reply to: CADastrophe
Many thanks for the help guys.
Perfect. Then better to move the tags rather than the drawing. this answers my question.
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
