I am trying to align the curtain wall with the edge of the concrete slab/face of wood framed wall (Core). I have tried to align and move however the whole wall moves as well as the edge of the slab. Any idea on how I can move the Curtain wall leaving the other elements in place?
What you need to do is select the curtain wall jamb (or mullion as Revit calls it) and choose the edit type button and play with the Offset value until you get the desired result. You can repeat this with the Curtain Panel. You may need use the tab button to select the Curtain Panel
http://www.screencast.com/t/yeOFcYmalz
You can move the curtain wall without moving the adjacent wall by either one of these methods:
Thanks for this post, almost 10 years later!
After successfully moving my 'Curtain Wall 1' element using Alfredo's solution, I tried copying the window but it won't automatically embed. Is that because of disallowing the join?
