Not a section within a section. But rather a callout within a section or
elevation. Callouts are parallel as I mentioned. You are correct that a
section in a section is unconstrained, but that isn't the issue here.
Go to the view in question. Right click and find refering view and find the
view showing the callout.
wrote in message news:5633836@discussion.autodesk.com...
I tried repeating what you said and it didn't work the way you described.
I went to a section, and created a section within that section. Then I went
to a plan view and was able to successfully move the new section marker in
any direction that I wanted. It was not constrained.
But I do appreciate your time in trying to help me with this issue. Thank
you.
