Move project to the 0,0,0 of the intern coordinate?
0 REPLIES 0
Message 1 of 1
dupuisj
560 Views, 0 Replies
Is there a way to move a project to the 0,0,0 internal coordinate of Revit? I often have to insert different Revit link in a project so I’m trying to make easier the insertion of a revit link (for example a structure Revit link into architecture Revit file. If all the Revit file use the point (0,0,0) of the Revit project internal coordinate, I could use origin to origin to place the link without having to move the link. I know that I can use the shared parameters but I have to place manually the link at the right place the first time. Is there another way to do this? I tried to use the API to move the project, but I have got problems to move elements that are associated with a Work Plan and to move on the Z axis.
Thanks.
Tags (1)
0 REPLIES 0
