Move elements between worksets
5 REPLIES 5
pevelor
4426 Views, 5 Replies
Hi
I am trying to move multiple elements from one workset to another.
Everyone on my team have synchronized and closed their file. I have made all worksets editable.
However, I am still unable to change the workset.
Can anyone explain how I can do it or refer me to some information.
Kind regards
Peder
Tags (2)
5 REPLIES 5
CoreyDaun
in reply to: pevelor
Have you synchronized/Reloaded Latest? If so, then select one of the elements of which you cannot change the Workset. Under Properties, does it report a user name for the parameter "Edited by"?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
pevelor
in reply to: CoreyDaun
I have synchronized latest, and in the properties box the edited by box is blank and grayed out.
CoreyDaun
What Category of elements are you trying to change the Workset of? Annotation elements (text, tags, title blocks) do not belong to the user-created Worsets like model elements do, so you cannot change them. If you are selecting a group of elements, use the filter to remove the annotation elements from the selection.
Hi, im trying to move elements too from one workset to another but, i only can select by group. Sorry im newest in this.
Im trying to move pipes that make interference with mine.
Can somebody helpme?
Elements inside a group belong to the workset assigned to the group.  You cannot change them without ungroup it.
