Hi
I am trying to move multiple elements from one workset to another.
Everyone on my team have synchronized and closed their file. I have made all worksets editable.
However, I am still unable to change the workset.
Can anyone explain how I can do it or refer me to some information.
Kind regards
Peder
Have you synchronized/Reloaded Latest? If so, then select one of the elements of which you cannot change the Workset. Under Properties, does it report a user name for the parameter "Edited by"?
What Category of elements are you trying to change the Workset of? Annotation elements (text, tags, title blocks) do not belong to the user-created Worsets like model elements do, so you cannot change them. If you are selecting a group of elements, use the filter to remove the annotation elements from the selection.
Hi, im trying to move elements too from one workset to another but, i only can select by group. Sorry im newest in this.
Im trying to move pipes that make interference with mine.
Can somebody helpme?
@CoreyDaun wrote:What Category of elements are you trying to change the Workset of? Annotation elements (text, tags, title blocks) do not belong to the user-created Worsets like model elements do, so you cannot change them. If you are selecting a group of elements, use the filter to remove the annotation elements from the selection.
Elements inside a group belong to the workset assigned to the group. You cannot change them without ungroup it.
