Mouse wheel zoom factor
4 REPLIES 4
1383 Views, 4 Replies
Hi
Is there a way to change the amount it zooms in with each click turn of
the mouse wheel.
Similar to ZOOMFACTOR in AutoCAD?
cheers
Dave F.
4 REPLIES 4
This is simply based on your windows mouse settings. Change it in the
control panel...
"Dave F." wrote in message
news:5479313@discussion.autodesk.com...
Hi
the mouse wheel.
cheers
Dave F.
> control panel...
> Hi
> the mouse wheel.
> cheers
> Dave F.
No, that doesn't work with my set-up.
Why do you think that would be the answer?
Does it affect yours?
Dave F.
Yes it does...
news:5479958@discussion.autodesk.com...
> control panel...
Dave F.
Aaron Rumple wrote:
> Yes it does...
Just to double check, is it the number of lines to scroll option that
you've changed?
You have your bog-standard mouse driver & not one of those add-ons for
mice such as KatMouse.
If it is, Hmm... Back to the drawing board.
Cheers
Dave F.
