Hi all,
My mouse has stopped panning completely. Is this an update issue does anyone know?
I previously had problems with 2013 when i detached the project browser and properties pallets, the ribbon stopped showing correctly.....maybe this is the same thing. Any help much appreciated.
Adam
Solved by rosskirby. Go to Solution.
It's most likely an issue with your mouse, not with Revit. None of the updates would have affected that, unless perhaps you're using one of those 3D mice (mouses?). I know they have some special programming associated with them, and that may have been affected. Try another mouse and see if you can replicate the issue. If not, then it's definitely a problem with the mouse.
