My stairs go from Level 1 to 2 and join a concrete floor at level 2.
The stairs are monolithic.
The problem I have is that at the top of the stairs the end riser can be seen and so it appears as an extra tread when viewed in plan.
See attached file, the red cross marks the lines which I need to remove.
I cannot join the stairs to the slab.
How can I remove these lines - is there something better than a masking region? can I set something in the family?
Cheers.
Solved by alex60. Go to Solution.
Hi archie, this is one of the most common issue in Revit, the only way that I have founded to solve this is streching the last riser to form the landing, see the attached image. If it is not possible in your project, try to use linework command with invisible lines to hide those lines.
I hope this help you
