Monolithic stairs - get rid of line at top?
2 REPLIES 2
Kevin.Bell
1772 Views, 2 Replies
My stairs go from Level 1 to 2 and join a concrete floor at level 2.
The stairs are monolithic.
The problem I have is that at the top of the stairs the end riser can be seen and so it appears as an extra tread when viewed in plan.
See attached file, the red cross marks the lines which I need to remove.
I cannot join the stairs to the slab.
How can I remove these lines - is there something better than a masking region? can I set something in the family?
Cheers.
2 REPLIES 2
alex60
in reply to: Kevin.Bell
Hi archie, this is one of the most common issue in Revit, the only way that I have founded to solve this is streching the last riser to form the landing, see the attached image. If it is not possible in your project, try to use linework command with invisible lines to hide those lines.
I hope this help you
Kevin.Bell
in reply to: alex60
OK, thanks for your help. One for the wish list I guess?
