Monolithic stair u-shaped
3 REPLIES 3
glenn.roar.hoye
998 Views, 3 Replies
I have made a stair by sketch, an u-shaped one. I do have som problems with the 3d modell. it will not show up correctly. I add som printscreens and you can see. You know what i have to do to fix this?
3 REPLIES 3
doni49
in reply to: glenn.roar.hoye
The first thing that comes to mind is that the view is cropped.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Hi
Use one of the following methods may be your problem.:
1 - Reduce the thickness of the stairs.
2 - in the landing areas, with separate Split.
3 - In the Type Properties and Type Properties dialog box, click Run type in new window Stepped put option on the Underside Surface.
4-Monolithic type steps of change.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
ppinedo1
in reply to: GHASEM_ARIYANI
Everyone should thank you so much!
