Revit Architecture
Revit Architecture
Member
smyroglou.b
Message 1 of 8 (1,449 Views)
Monolithic Stair - How to Display Only Concrete in Plan View
1449 Views, 7 Replies
04-23-2012 09:56 AM
Hello.
I use all the time L shape and U shape winder stairs in combination with the Monolithic Type.
We use to concrete the monolithic part of the stairs and then dress the stairs with treads and risers.
The new tool looks that working very nice.
So OK I draw the U shape winder stair and of course i want to construct the stairs.
I want to prepape a detail plan view with dimensions only for the Monolithic Part (Concrete) of the stair but i can't find a way to dispay only the monolithic part without Treads and Riser.It is possible in 3d view but no in plan view.
The news tool that calculate winder stairs is "half job done" if i can't print with dimension the concrete part of the winder stairs.
Thanks in advance.
Vasilis
It is strange. It is the second strange thing I see in these new Stairs by component.
Well, if that does not work with Visibility Graphics, I would do this, then: from the top 3d view, do > Model lines > Pick lines  > pick all the lines that you need. Go back to the floor plan. Select all around the stairs > Filters > Model lines > Convert lines. This will convert all the model lines into Detail lines. Make a group, that includes the stair and the detail lines. Now, add the dimensions.
Product Support
alan.quinn
Message 2 of 8 (1,416 Views)
Re: Monolithic Stair - How to Display Only Concrete in Plan View
04-24-2012 02:04 PM in reply to: smyroglou.b
Can you upload an example. Copy the stair from your file > purge and post.
Thank you,
Alan Quinn
Support Specialist
Product Support
Member
smyroglou.b
Message 3 of 8 (1,410 Views)
04-24-2012 02:18 PM in reply to: alan.quinn
This is a 30 second example from my template.
Thank you for your help.
Alfredo_Medina
Message 4 of 8 (1,405 Views)
04-24-2012 02:42 PM in reply to: smyroglou.b
What if you go to Visibility Graphics > Stairs , and turn off Riser lines and Nosing lines? Would that be the kind of view that you need?
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Member
smyroglou.b
Message 5 of 8 (1,402 Views)
04-24-2012 02:56 PM in reply to: Alfredo_Medina
No ... if I do what you said I end up with the first view (attachment)
I want to end up to the second view (attachment) and display only concrete but in plan view mode in order to dimension.
The second attachment come from a 3d view in Top Orientation where when I turn off the VG --> Stairs --> Treads/Risers element Revit do what it has to do and turn off the Treads/Risers.
In plan view whatever I turn off from VG --> Stairs can't manage to turn off Treads + Risers.
The most strange is if i choose in Visual Style --> Wireframe I can't see the Concrete edges.
Alfredo_Medina
Message 6 of 8 (1,387 Views)
04-24-2012 03:20 PM in reply to: smyroglou.b
Product Support
alan.quinn
Message 7 of 8 (1,369 Views)
04-25-2012 07:02 AM in reply to: Alfredo_Medina
Sounds like a good solution. Thanks for posting.
Alan Quinn
Support Specialist
Product Support
Member
smyroglou.b
Message 8 of 8 (1,354 Views)
04-25-2012 12:26 PM in reply to: alan.quinn
Yes I have test it and is working ... but someone can explain why in Wireframe mode (Plan View) I can't see the concrete part of the stair and in the 3d View i can.
